Hi everyone,
Since the question is serious, allow me to go straigth to the problem.
I'm modeling a tank with a storage capacity of 100 cubic meters, the inflow of 51 l/s is provided by a constant power pump, while about the same outflow of 50 l/s (180 cubic meters per hour) is drawn by two pipes, each of them leads to the network's downstream zone. Considering one hour time step simulation, in theory, if the inflow falls to zero, the 100 cubic meters volume is not enough to guarantee the fixed outflow. After some hours of simulation the tank is filled and the inflow becomes zero: since the volume storaged is less than 180 cubic meters, the outflow over the next hour should be less than 50 l/s but the results show 0 in the pump and the same outflow as before. Examining the level in the tank, it is not even affected: it is only slightly less than the previous time step but it should be zero.
I have been looking for an explanation for weeks without finding anything and my deadline is approaching so, please help me.
