I need to extend the shaft on a 0.18KW single phase 4 pole flange mounted electric motor, the diameter of the shaft is 11mm and the key is 4mm (63F Frame). The shaft on the motor is currently 23mm long and I need to extend this by 500mm however most readily available shaft couplings have a diameter of 8,10,12,14mm etc.
I'm just wondering what the best option would be, would it be to design a bespoke part to fit or are there alternative solutions? Also as I'm new to working on this aspect of motors I'm just wondering why they sell motors with 9 or 11mm shafts when the most common couplings available are 8, 10 or 12mm couplings?
Thanks in advance, Max
