ElCidCampeador
- May 14, 2015
- 274
I have a nozzle (seamless pipe+standard WN acc. to B16.5) designed acc. to ASME VIII Div.1 with external loads acting at shell/nozzle intersection and checked acc. to WRC.
Question: Does UG-44(b) apply?
I mean, loads are acting not directly at flange joint, so may I assume "External loads (forces and bending moments)" of UG-44(b) equal to zero and skip UG-44 calculations?
If not, I suppose I have to verify flange according to appendix 2 (bolts are B7M material so they don't have an allowable stress greater than B8 Cl.2, as (b)(3) requires).
