Facundo9788
This is my firt entry.
I work designing and drafting vessels according to ASME DIV XIII Section 1 and the European Union Pressure Equipment Directive (PED).
I searched the ASME Code for grounding/earthing lugs an I didn't find specifications, then I searched the API 650 and found something but it is way to big for what I need, at least I saw that the lug must be Austenitic Stainless Steel no matter the vessel material. For welding then I must go for a 309L electrode if I combine Stainless and Carbon Steel.
What I really need to know and I didn't find and answer in the Code is: a pad, like the pad of a saddle, is considerer a pressure part UG-4(a) or a non pressure pad UG-4(b)?
What consideration shall I have for welding the grounding lug to the shell or to a pad welded to the shell?
Facundo.
Facundo.
