have a small query , if you have an idea please let me know . it is appreciated.
i am designing a external steel fire escape staircase as below. columns are pinned . all member connections are pinned . this need some bracing to not to too wobbly when is fully loaded (live load is 4kpa) and also to prevent deflection from wind . All threads and landings are checker plates .
My question is i m trying to find a way to make this without bracing
1. One i found it if we can have all columns fixed to the footings with bored piers , i found bracing not needed. but there is an existing one and after demolishing it we are going to use the existing footings if sufficient , so this option is not possible
2. If we have moment connections at top like in portal frames i think we do not need bracing( eg haunch). but i m not sure whether we can do it for small structures like stairs. can we do it for these small members , columns are 100SHS and all other members are 150PFC.
3. Any other way to make the stair case rigid and not wobbly?
any idea is appreciated .
