Extract Attribute value from User Defined feature with Journal, NX 11
3dr
Automotive
Jul 10, 2004
451
Is anyone doing this?
I've got a bunch of work from another design house and I'm doing this the hard way over and over detailing parts in drafting.
Select, Note
Select, Category Relationships
Select, Insert Object Attribute
Select, Filter drop down
Select, Face
Select, Object
Select, Leader Location
Select, Placement Location
OUCH!
TIA if anyone has a tool I can modify
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX1851, Win 10 Pro
thread561-457883
In the thread above, there is some code that allows the user to select a component in a drafting view then it reads a specific attribute from the component and prompts for a note location. A label is created (a note with a leader) referencing the attribute value. I think that it is the closest journal I have to what you are asking for.
www.nxjournaling.com
Thanks alot Cowski, I'll give it try.
Dave
NX1851, Win 10 Pro
