Hi
Setting the geometric non-linearity option on, the calculated SIFs are not accurate (Abaqus warning)as agreed they are specifically valid for a linear elastic material.
In such an analysis case when the geometric noo-linearity is considered (elastic material, so far) the J integral can be calculated. Is it possible to estimate the SIFs (K1,K11,K111)from J-Integral in nonlinear geometry? if so, how could use Abaqus input/output files, please?
