quark
- Jan 23, 2002
- 3,409
We are planning to use this Machine for extrusion of one HCl compound. The highest temperature zone is 180C and immediately cools down to 90C. Presently, the barrel MOC is X15TN and got corroded after taking some trials. Barrel is made of SS316 and the product contact sleeve is with X15TN. The manufacturer is suggesting 17-4PH as they need minimum hardness of 44 HRC. Even this material doesn't seem to be good for pitting corrosion. Request your suggestions on this or any other better material.
My search indicates X15TN to have better pitting corrosion control. I checked PRN for X15TN and is about 22.5. Usually,is this a better value?
