  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
F650
slavag
2,044
Hi.
Our customer would like use for MV protection GE relay F650.
We don't have any experience with this relay. More or less standard protection 50,51,51N, 67N ( with Peterson coil), 27,59, 49 . Some logiks for CB, control and meas.
Thanks for some information. ( no need any comercial data).
Regards.
Slava
slava--
Maybe I'm missing something. GE has the UR F60 feeder relay. It does all you ask about. I have installed and worked with several. It is an extremely capable and flexible platform.
They also have the SR 750/760, also a very good realy, but much less flexible than the UR platform.
I work in facilities which use both.
old field guy
slava,
What exactly is your question? Oldfieldguy is right, they are two different relays (F60 & SR750/760) but both very capable.
I have tested and set both and they are realtively easy if you have used micro-processor relays before.
It's a "Bay Controller" relay that seems similar to SR750 with addition of some graphics. Mainly marketed outside the US. I guess the "bay control" concept is defined in IEC-land somewhere. SEL makes one also, I think.
We ran into some up in Canada.
I have one customer with three F650's supplied with GE's equivalent to a recloser. We've had issues with the performance of the relays frequency response and reclosing.
