drewpe
- Jul 16, 2014
- 3
I am looking at providing fall arrest anchor supports for new fall arrest anchor systems going into an existing steel building will steel roof joists. The new fall arrest anchor system is designed for an ultimate load of 1,800 lbs (900 lbs w/ safety factor of 2) and they are looking to support it off the bottom of the existing joists. My question is a two part question:
1) Is it reasonable to reduce the load by a factor of 1.6 to account for the fact that I am checking the joists for allowable loads?
2) Is there an acceptable over-stressed limit that these joists can be under to account for the fact that these are impact loads and not sustained loads?
Thanks in advanced.
Thanks in advanced.
