skeletron
- Jan 30, 2019
- 881
Is there any way to test a fall arrest anchor and incorporate a bi-directional load? All the testing devices I see are straight-pull. CSA Z271 addresses the test load (11kN) and no permanent deformation. CSA Z259 addresses that the anchorage connector must be tested in all directions of the load for which will be applied.
Side-pull testing: you would almost have to chain two anchors together and then apply a load to both anchors. Is there any other way to practically do it?
My concern with the straight-pull test is that it wouldn't show "permanent deformation" as per the standard's requirement for testing.
