BSVBD
- Jul 23, 2015
- 462
I've reviewed the 2014 Eng-Tips post entitled "OSHA Fall Arrest System".
There is apparent debate, indecision and, unless I do not understand, no apparent credible conclusion regarding what load must be applied to the structure supporting Fall Protection "Systems".
Lanyards... 5,000 LBS.
Self-retracting lifelines and lanyards... 3,000 LBS.
D-rings, snaphooks and carabiners... 5,000 LBS proof tested at 3,600 LBS.
Anchorages... 5,000 LBS.
Travel Restraint Lines... 5,000 LBS.
(MAF) Maximum Arresting Force on employee = 1,800 LBS.
Initial Arresting Force... 2,000 LBS.
Subsequent Arresting Force... 1,000 LBS.
The arresting forces seem to be the (reasonable) relevant load(s) to apply to the structure.
All of our time is valuable. I will contact OSHA and local and state reviewers when and if permissible. Until then, has anyone contacted any legal authority for such conclusion or advice?
Other thoughts?
Thank you!
Other thoughts?
Thank you!
