fan motor
PwrBuf
theoretically, what happens when a fan is off and wind is spinning the fan blades opposite the running direction and you then turn the fan motor on? does the fan motor draw locked rotor current til the fan reaches full speed in the running direction or is more than locked rotor current drawn while fan is reversing?
I believe it will draw pretty close to locked rotor current (same magnitude as normal start), but only for a longer time than a normal start.
There are two odd-ball factors that may alter that situation slightly.
1 - locked rotor current can be obtained from equivalent circuit using s=1. If you solve using s=1.1 corresponding to 10% backward speed I think you will get a number slightly higher. I believe this number is valid but the difference is small, especially when reverse speed is slow.
2 - residual magnetism in the rotor may create some stator voltage in the spinning motor. If that voltage opposes the applied voltage at the moment of energization it seems to me there may be slightly different transient of the exponentially-decaying dc offset component than normal (possibly higher dc component than normal).
I think both these effects if they exist at all are small.
Suggestion: The fan manufacturer may have added a small design margin for this phenomenon. Normally, there are motors on the marked that are designed for "plugging" duty, e.g. tool motors. These motors withstand rotational direction reversals at full speeds from one direction to the other and vice versa. They have oversized cooling systems to be able to dissipate amout of heat generated by the motor direction of rotation reversals.
