ARenko
- Jan 30, 2001
- 178
We have some equipment installed under the rig floor on a drilling rig where KCL mud is used. We are adding a carbon steel cover to add some protection from impact and this cover will have to be periodically removed for servicing the equipment. There's concern that corrosion of the fasteners preventing removing the cover when it's necessary to service the equipment. We intended to use weld nuts on the back side of a carbon steel plate that the cover will bolt onto. What would be suitable materials and/ or coatings for the nuts and bolts in this application?
