Fatal Error????
marbrown
3
Ok, here's the situation.
I'm working with a landbase file and am trying
to set it up to design with. The only thing is
that about a couple of hours into cleaning it
up I get this Fatal Error message.
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 88f46ch
Has anyone seen this or delt with this issue before?
Mark.
Most common source of this kind of error is writing beyond
the range of an array into the code and next trying to execute it.
<nbucska@pcperipherals DOT com> subj: eng-tips
nbucska is correct. Also pointer errors. You walked through zero. That is a trademark of a pointer error or a write to program memroy instead of data memory. We would need to know more about your system.
