Fatigue assessment in vertical Vessel supported by brackets
raulcc
4
thread794-501203
Dear All,
I hope this thread finds you well.
I have a question regarding the necessity of performing a Fatigue assessment
Currently, I am designing a vessel with the design pressure and temperature of 4 4barg and 80C. Nothing special, but operate in batches a fluid that is heavier than water by 20%. The vessel is filled up to 90% level, and then emptied to 15% level, every 20 min. this gives 72 cycles per day @ constant pressure and temperature.
The load on the Brackets is about 10 tons per support, (total of 40 tons when 90% full)
What do you think should be done? it is necessary the fatigue assessment in this case.
Thanks for your time.
Kind regards,
RACC.
72 cycles a day for 25 years is 657,000 cycles. That’s less than the 1,000,000 that would make a fatigue analysis mandatory, but that’s still a substantial number of cycles. At a bare minimum, I recommend performing a Method B fatigue screening assessment to determine whether or not to perform a full on fatigue analysis.
Grind fillet welds to a radius and liquid Penetrant examination.
