kaffy
- Jun 2, 2020
- 191
Good Morning Fellow Engineers,
I am trying to determine the generated reaction loads at bolted joints when a horizontal force acts on center of gravity of machine (Seismic Loads).
My original Intent was to use the following approach
-Create a coordinate system at COG of machine
-Create a split surface (Bottom surface of top flange as shown in screenshot #2). Split surface is created to mimic the flat washer
-Apply a remote load at coordinate system and Connect the remote load to the faces shown in screenshot #2
-Run FEA and check reaction loads at the faces
*Since I am not interested in checking the base part, I will use a lot of stiffeners etc. to stiffen it up so the stress in part does not go beyond the yield stress
*I am planning to use remote load (direct transfer)
I have the following questions.
-Is there any alternate / Better approach to solve those kind of problems?
-Is using the remote Load (direct transfer) correct in this application or should I use Remote load (rigid connection)? If Rigid Connection, Why? Screenshot #3 has the explanation of both cases
-Any other free online tool available to analyze those kind of problems?
Thank you very much
Thank you very much
