azmirosman
Dear All,
Good Day.
I would like to request your opinion regarding the ferrite count on the weld overlay.
Currently, I am involved in fabrication of3 units of pressure vessels made of SA516 Gr. 70 clad with SS316L.
As per my company's requirement, the ferrite content shall be as below:
The ferrite content of the weld overlay of the production welds at a depth
of 2 mm shall be determined to the following extent:
- One analysis per course; one analysis per each head and one analysis
for each nozzle.
The ferrite content shall be between 3% and 8%.
The overlay area are at all area that having CS to CS weldment such as nozzle flange face, nozzle to shell joint and shell to shell joint (capping)with 3.5mm thick.
As per current inspection result, many of the ferrite content reading is exceed 8% (Ranges from 8.5% to 11.5%).
Because this vessel's design temperature is only 120 °C and it is only 27 mm thick plus 3 mm of cladding (no PWHT or impact test), our fabricator requests that all points with reading areas less than 12% be accepted.
I need to convince my technical authority to accept the reading, but I need a basis to explain it to them.
Really appreciate if anybody can advice if this situation can be accepted.
Thank You
Good Day.
for each nozzle.
Thank You
