azizur447
Materials
- Aug 14, 2013
- 26
We got a valve cast body from a foundry. The body made from SA-995 grade 4A they give the result of Ferrite content 52% tested I.A.W ASTM E 562 of the cast body. Our allowable ferrite range is 35% to 55%.
But after machining it and tested ferrite content on the machined surface with Fischer Ferrite Scope and shows the result above 60%. Ferrite Scope has been calibrated with standard sample.
