Fig 7-39/2018 question
greenimi
2,316
In fig 7-39/ ASME Y14.5-2018
I think we all agree that the two bores should be “squiggly” (in the same way the outside diameter is shown a little “bumpy”), but my question is:
Do you think the correct way is to show the two (“squiggly” to be) holes slightly rotated clockwise? (my red adjustements)
I am comparing 7-38 with 7-39 and I am wondering why the holes in 7-39 are not rotated? Should they be? Shouldn’t they be?
Fig 7-38 looks okay, but if the intent is to show the same part on both scenarios (with and without the translation modifier) then why 7-39 does not show rotated holes?
Hi Greenimi,
Can you also share Fig. 7-38? I don't own a copy of the spec.
Then if you own (and I expect as a trainer you do) 2009 version of the ASME Y14.5 then figure 4-32 is the one you want to reference.
They are showing the rotation of the datum feature . The features referring to won't rotate.
Why not rotate? Isn't it the same part as in fig 7-38?
I think it is the same intent......
Sorry, I do not. When I was directly employed the company had a copy. I never bought one for myself. I am not a GD&T trainer, just an experienced user. Are the older versions available for free download (legally)?
It is not the same part. It is showing that the datum features are different for the same result.
greenimi,
Had 7-39 been showing the holes rotated that would suggest the translation modifier provides some kind of additional leeway for the holes (like datum shift), but that is not the case.
So what that does mean? That the datum reference frame does not matter? Therefore, regardless of the datum features you can get the same result?
Same type of comparison made in Fig. 7-36 vs. Fig. 7-37 and so on. The features don't move, the datum features do.
The datum features are limited by the tolerances qualifying them and don't "move". The datum feature simulator for the clocking datum feature is allowed translation and is unfixed from its basic location relative to the primary datum A axis, to allow better engagement with the actual, as-produced datum feature B.
Well, in fig 7-39 we are NOT talking abot clocking. We are talking about aligning.
So I would say that orientation determines the alignment of the remaining axes of the datum reference frame.
I think clocking is applied when no translation modifier is used (fig 7-38).
So, I am saying that the physical reality of the part in fig 7-39 will make the 2 holes (the patten) to rotate slightly, clockwise.
I disagree, 7-39 IS about clocking too. Will explain later if no one else will before me. Stay tuned.
