Figure F.2
TheEverest
NP
How do we calculate exact value of 'Le' in Figure F.2?
I found that the maximum value of 'Le' could be 250/(Fy)^0.5 mm or 3000/(Fy)^0.5 inch. But could not find the exact formula to calculate 'Le'.
Everest ...
Which API code are you referring to ? ... Can you give us a little more effort here ???
MJCronin
Sr. Process Engineer
Read the note 3 again...
3. The unstiffened length of the angle or bar said:
multiplied times ta for details a through g or times tb for details h through k, where Fy is the minimum specified yield strength, MPa (lbf/in.2).]
for details a through g Le ≤( 250/(Fy)^0.59* ta
for details h through k Le ≤( 250/(Fy)^0.59* tb
