Dec 7, 2021 #1 Cobra17 Mechanical Jun 18, 2020 158 0 0 CA Is there a formula or somewhere that has table values for the MDMT reduction curve of Figure UCS-66.1?
Dec 8, 2021 #2 david339933 Industrial Jun 15, 2011 1,204 0 0 CA Not for a reduction of more than 40F. Upvote 0 Downvote
Dec 8, 2021 #3 SnTMan Mechanical Jan 22, 2005 6,780 0 36 US Looks like it would be fairly easy to curve fit it. Using a spreadsheet or a website like this one... Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Dec 9, 2021 Thread starter #4 Cobra17 Mechanical Jun 18, 2020 158 0 0 CA I did it the "long" way... only took an hour. I used Compress to get the reduction for stress ratio's from 0.35 to 1.00 using 0.01 ratio increments. might not have been the easiest way, but it works and matches compress exactly when it interpolates. Upvote 0 Downvote
