File Path
PDW
Automotive
Oct 13, 2010
110
Dear all,
Based on the Journal created by UGperson Link, i would like to do something similar.
But i have another folder structure and 2 different folder quantitys
With below journal, it is fully functional in case I have 4 Folders.
In Case I only have 3 folders, it is extracting the wrong Folder information.
Anybody willing to support on this to have it working for both folder structures?
Best regards,
Pascal
Working on NX11, No TC
Code:
'Release "QUA_Set_PartFileAttributes.vb"
'Drive:\Customer\XXXX\Mould\Final\XXXX-YYY.prt
'Drive:\Customer\XXXX\tool\XXXX-YYY-ZZZ.prt
'This journal updates, based on the OS File Name, several extracted Attributes
'FILE_PATH
'FILE_NAME
'Part_Spec
'PART_NAME
'MOULD_NR
'CUSTOMER_NAME
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module NXJurnal
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Sub Main
workPart.SetAttribute("FILE_PATH", GetFilePath())
workPart.SetAttribute("FILE_NAME", GetFileName())
workPart.SetAttribute("Part_Spec", (GetFilePath() & GetFileName())&".prt")
workPart.SetAttribute("PART_NAME", GetFilePartName())
workPart.SetAttribute("MOULD_NR", GetFileMould())
workPart.SetAttribute("CUSTOMER_NAME", GetFileCustomerName())
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
lw.WriteLine("Path        : " & GetFilePath)
lw.WriteLine("Name        : " & GetFileName)
lw.WriteLine("Customer    : " & GetFileCustomerName)
lw.WriteLine("Mould       : " & GetFileMould)
lw.WriteLine("Part Number : " & GetFilePartName)
'Dim user_name As String = System.Environment.ExpandEnvironmentVariables("%username%")
'workPart.SetAttribute("Name", user_name)
End Sub
'QUA_Set_PartFileAttributes
Function GetFileName()
	Dim strPath as String
	Dim strPart as String
	Dim pos as Integer
	'get the full file path
	strPath = displayPart.fullpath
	'get the part file name
	pos = InStrRev(strPath, "\")
	strPart = Mid(strPath, pos + 1)
	strPath = Left(strPath, pos)
	'strip off the ".prt" extension
	strPart = Left(strPart, Len(strPart) - 4)
	GetFileName = strPart
End Function
Function GetFilePath()
	Dim pos as Integer
	GetFilePath = strPath
End Function
Function GetFilePartName()
	Dim pos as Integer
	Dim e as Integer
	Dim L as Integer
	strPath = Right(strPath, pos)
       'strip off the "xxx-xxx-xxx-_"
	strPart = Right(strPart, Len(strPart) - 5)
	GetFilePartName = strPart
End Function
Function GetFileCustomerName()
	Dim strPart1 as String
	Dim strPart2 as String
	Dim strPart3 as String
	Dim strPart4 as String
	Dim pos as Integer
       Dim pos1 as Integer
       Dim pos2 as Integer
       Dim pos3 as Integer
       Dim pos4 as Integer
	strPart = Left(strPath, pos - 1)
       pos1 = InStrRev(strPart, "\")
	strPart1 = Left(strPath, pos1 - 1)
       pos2 = InStrRev(strPart1, "\")
	strPart2 = Left(strPart, pos2 - 1)
       pos3 = InStrRev(strPart2, "\")
	strPart3 = Left(strPart2, pos3 - 1)
       pos4 = InStrRev(strPart3, "\")
	strPart4 = Mid(strPart3, pos4 + 1)
	GetFileCustomerName = strPart4
End Function
Function GetFileMould()
	Dim pos as Integer
	   Dim pos1 as Integer
       Dim pos2 as Integer
       Dim pos3 as Integer
	strPart3 = Mid(strPart2, pos3 + 1)
       'pos4 = InStrRev(strPart3, "\")
	'strPart4 = Mid(strPart3, pos4 + 1)
	GetFileMould = strPart3
End Function
End Module
