Hi all,
I have a project where I need to fill up about 60m3 of existing humus tank as per hatched area in attached file (dims in mm). The new working height of the tank will be only 1300mm and store water. The new formation level would be built on top of hatched area and probably in the form of reinforced slab.
Is there any cheaper/greener alternative to a foamed concrete? Maybe someone had a similar project in the past?
Thank you in advance,
Jed
Jed
