Hi Dears,
I am looking for a silicone rubber that compatible with my epoxy and polyurethane resins. The reason I am asking this is that I used a Polyaddition Silicon named ''ESSIL 291'' from Axon. However, after 5 castings, a white layer started to appear on my silicone which with more casting turned into a thick yellewish layer.
My epoxy Resin is called: Fast Cure Graffitte Resin. See:
Please keep in mind that my epoxy is two parts. Part A is bisphenol-A-(epichlorhydrin) epoxy resin. Part B is 3-aminomethyl-3,5,5- trimethylcyclohexylamine
My Polyurethane Resin is:
Keep in mind that my epoxy is two parts. Part A consists of two chemicals: (Diphenylmethane-4,4’-diisocyanate(MDI)), and ( 2,2,4-trimethyl-1,3-pentanediol diisobutyrate).
Part B consists of three chemicals: (N, N, N’,N’-tetrakis(2-
hydroxylpropyl)ethylenediamine), (2,2,4-trimethyl-1,3-pentanedioldiisobutyrate), and (Diethylene glycol)
I am looking forward to hearing from you.
Best regards,
Best regards,
