FindObject in Assembly
YviKyvi
12
Hey,
I try to create a plane on a face in an assembly. I know I have to wavelink the component of the face, but I can't figure out how it works.
I have to replace these FindObject lines from the recorded journal:
Code:
Dim face1 As NXOpen.Face = CType(component1.FindObject("PROTO#.Features|CYLINDER(1)|FACE 1 {(0,0,172) CYLINDER(1)}"), NXOpen.Face)
Dim face2 As NXOpen.Face = CType(extractFace2.FindObject("FACE 1 {(85.2937910603973,125.9999999999999,-0) LINKED_FACE(8)}"), NXOpen.Face)
I already found this thread: but I can't work with the LINKED_FACE(0), because I want to choose any of the faces.
I am using blockstyler for the selection with the selectObject method.
My Code is not working like I want it to, because it's using only the position of the face in the linked body but not the position of the face in the assembly.
That's my little changed recorded journal:
Code:
    Public Function makePlane()
        Dim displayPart As NXOpen.Part = theSession.Parts.Display
        Dim nullNXOpen_Features_Feature As NXOpen.Features.Feature = Nothing
        Dim datumPlaneBuilder1 As NXOpen.Features.DatumPlaneBuilder = Nothing
        datumPlaneBuilder1 = workPart.Features.CreateDatumPlaneBuilder(nullNXOpen_Features_Feature)
        Dim plane1 As NXOpen.Plane = Nothing
        plane1 = datumPlaneBuilder1.GetPlane()
        Dim unit1 As NXOpen.Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), NXOpen.Unit)
        Dim expression1 As NXOpen.Expression = Nothing
        expression1 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
        Dim expression2 As NXOpen.Expression = Nothing
        expression2 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
        Dim coordinates1 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
        Dim point1 As NXOpen.Point = Nothing
        point1 = workPart.Points.CreatePoint(coordinates1)
        plane1.SetUpdateOption(NXOpen.SmartObject.UpdateOption.WithinModeling)
        Dim extractFaceBuilder1 As NXOpen.Features.ExtractFaceBuilder = Nothing
        extractFaceBuilder1 = workPart.Features.CreateExtractFaceBuilder(nullNXOpen_Features_Feature)
        extractFaceBuilder1.Type = NXOpen.Features.ExtractFaceBuilder.ExtractType.Face
        extractFaceBuilder1.ParentPart = NXOpen.Features.ExtractFaceBuilder.ParentPartType.OtherPart
        extractFaceBuilder1.Associative = True
        Dim selectDisplayableObjectList1 As NXOpen.SelectDisplayableObjectList = Nothing
        selectDisplayableObjectList1 = extractFaceBuilder1.ObjectToExtract
        Dim tagObj As NXOpen.TaggedObject() = selection0.GetSelectedObjects
        Dim face1 As NXOpen.Face = CType(tagObj(0), NXOpen.Face)
        Dim added1 As Boolean = Nothing
        added1 = selectDisplayableObjectList1.Add(face1)
        Dim feature1 As NXOpen.Features.Feature = Nothing
        feature1 = extractFaceBuilder1.CommitCreateOnTheFly()
        Dim waveLinkRepository1 As NXOpen.GeometricUtilities.WaveLinkRepository = Nothing
        waveLinkRepository1 = workPart.CreateWavelinkRepository()
        waveLinkRepository1.SetNonFeatureApplication(False)
        waveLinkRepository1.SetBuilder(datumPlaneBuilder1)
        Dim extractFace1 As NXOpen.Features.ExtractFace = CType(feature1, NXOpen.Features.ExtractFace)
        waveLinkRepository1.SetLink(extractFace1)
        Dim extractFaceBuilder2 As NXOpen.Features.ExtractFaceBuilder = Nothing
        extractFaceBuilder2 = workPart.Features.CreateExtractFaceBuilder(extractFace1)
        extractFaceBuilder2.Associative = False
        Dim feature2 As NXOpen.Features.Feature = Nothing
        feature2 = extractFaceBuilder2.CommitCreateOnTheFly()
        extractFaceBuilder2.Destroy()
        Dim extractFace2 As NXOpen.Features.ExtractFace = CType(feature2, NXOpen.Features.ExtractFace)
        extractFace2.SetName("Fläche")
        extractFaceBuilder1.Destroy()
        plane1.SetMethod(NXOpen.PlaneTypes.MethodType.Distance)
        Dim geom1(0) As NXOpen.NXObject
        Dim face2 As NXOpen.Face = face1
        geom1(0) = face2
        plane1.SetGeometry(geom1)
        plane1.SetFlip(False)
        plane1.SetReverseSide(False)
        Dim expression3 As NXOpen.Expression = Nothing
        expression3 = plane1.Expression
        expression3.RightHandSide = CType(integer0.Value, String)
        plane1.SetAlternate(NXOpen.PlaneTypes.AlternateType.One)
        plane1.Evaluate()
        plane1.RemoveOffsetData()
        plane1.Evaluate()
        datumPlaneBuilder1.ResizeDuringUpdate = True
        Dim feature3 As NXOpen.Features.Feature = Nothing
        feature3 = datumPlaneBuilder1.CommitFeature()
        Dim datumPlaneFeature1 As NXOpen.Features.DatumPlaneFeature = CType(feature3, NXOpen.Features.DatumPlaneFeature)
        Dim datumPlane1 As NXOpen.DatumPlane = Nothing
        datumPlane1 = datumPlaneFeature1.DatumPlane
        datumPlane1.SetReverseSection(False)
        datumPlaneBuilder1.Destroy()
        waveLinkRepository1.Destroy()
  End Function
Any help is highly appreciated!
Yvonne
Okay, I just found it.
Trial and Error - so the NX Open documentation wasn't really helpful.
If somebody got stuck on the same point, here is my solution:
Code:
'refers to the occurrence of the face in the assembly
'refers to the wavelinked face
 Dim linkedFace() As NXOpen.Face = extractFace2.GetFaces
 Dim face2 As NXOpen.Face = linkedFace(0)
