For a Gas Treatment Plant, at the inlet of the plant coming with multiphase pipeline, there is a 850 m3 capacity finger type slug catcher after the pig receiver. In the rest of the system, there are mainly gas dehydration, condensate separation & stablization, export gas compression, HP and LP flares, MEG and TEG regeneration, water treatment sub-systems.
The Owner decided to increase the liquid slug size of slug catcher from 850 m3 to 1650 m3. Could you please advise which kind of other connected sub-systems and units can be affected from this increase? What will be the possible results on sub-systems on size or capacity manner? Will there be any increase on their capacity or size?
Thank you.
Thank you.
