I have a pressure vessel (design press: 3.5 barg) with a conventional PRV and a end of line PVRV mounted on top.
For PVRV I issued an inquiry to a vendor and asked them to size it as per API 2000 under fire case scenario. But PVRV vendor is regretting to quote as they claim that since PVRV is mounted on a pressure vessel, API 2000 cannot be used for sizing. I checked API 2000 and its pretty clear that its applicable for low pressure tanks of pressure upto 15 psig only. I am now wondering which standard can be used to size this PVRV since vendor is not aware of this as well. I dont want to use API 520 because I understand the size of this PSV will be very high and wont be in our budget.
Can anyone suggest a more economical way to size this PVRV?
PS: It might sound weird to have a PVRV and a PRV both on the tank at the same time. but this is client requirement so I need to supply this PRV even though its never going to be used as it is set at higher set pressure than PVRV.
