Fire damper
mech9188
4
Hi all,
i am preparing technical spec for motorized fire damper for HVAC system.
If anyone have technical datasheet for the same, please send me.i required it for my reference.
Use Google to find several manufacturers. Get their technical data and guide specs, I've yet to see any manufacturer unwilling to share. Use one or more as a guide to create a generic spec for your use.
Thanks @ dbill74.
Will wait for your response.
Don't be waiting on me, you'll be waiting a very long time.
You need to do your own leg work on this.
Fire dampers aren't motorized. they operate via a fusible link that closes the damper at a certain high temperature. Are you referring to smoke dampers?
Combo fire/smoke dampers are common. The smoke function works an actuator; the fire function melts a link that springs the dampers closed. There are a lot of misconceptions about these things.
Fire dampers can be motorized, although not needed in most applications.
Add: One application for using a motorized damper is when the duct is vertical and penetrates a floor or other horizontal barrier.
I have new project in that my client want to replaced all fusible link fire damper to motorised fire damper.
