nuuvox000
- Sep 17, 2019
- 344
In IBC 714.3.1.2 (with IMC 607.1.2 in mind), it says (paraphrasing) that you can use an ASTM E814 tested penetration firestop system in lieu of fire dampers. I am looking at the UL listings on the 3M website and some of the duct penetrations are listed as large as 30"x24" with just some fire wrap and fire caulk.
I'm just thinking about what happens when there is a fire in the room; won't the fire spread through the 30"x24" opening quite easily? (assuming the duct stops inside the room right after penetration, think of a transfer air duct between rooms). It just seems strange that they're so worried about the annular space around the penetration and not the size of the penetration itself. Any thoughts and comments are appreciated as I am still an engineer in training.
Thanks!
Thanks!
