Lightweight construction is one of those terms the fire service invented and now it's found it's way into many discussions. Lightweight construction is a term that describes certain wood framing systems used in single family dwellings (and a fair amount of multi-family dwellings) construction. I've typically equated the fire service's use of the term
light weight construction as a categorization of the use TJI joists and beams and wood trusses constructed with staples or stapled gusset plates. It's a completely legal system of construction but under fire exposure it has a tendency to fail rapidly. When I explain lightweight construction to fire fighters, I always include the phrase "less mass but more math." In other words, as computing power has increased and the methods of construction have advanced, engineers have been able to develop less expensive designs for constructing wood-frame buildings while still meeting the design load and load path requirements in International Building Code and ASCE 7.
If the FDC location is creating this much drama, one approach to take is how the building is protected. If this is a NFPA 13 sprinkler system and if the building is combustible construction, one could possibly justify locating the FDC on the building based on it's occupancy, how the concealed spaces are protected, and comparing this to US Fire Sprinkler Performance data published by NFPA. If the building is 1 story business or mercantile occupancy, is accessible from all sides by the Fire Department, and the FDC can be located at a corner so the firefighters have an escape path, one could at least show that the fire loss history in the buildings is so low in sprinklered buildings that the expense of a remote FDC is not justified. The approving FD may have an amendment that requires remote FDCs.
To your question:
John 187 said:
Is this a consideration for why a remote FDC is preferred by the fire marshall? If so, are you aware of what code this is coming from? Thanks
We don't know. If this project is in the US, the jurisdiction probably has adopted either the
International Fire Code or NFPA 1,
Fire Code. If the IFC has been adopted, Section 912 establishes requirements for the the installation of FDCs. I rarely use NFPA 1 so I don't know if it has specific provisions for FDCs. I suspect so but I've just never looked. Ask the fire code official for the code section being referenced.
