Fire Hose Replacement
MarsMax
18
Hi guys,
I want to determine if I can replace a 75’ hose to 100’. The fire pump is located at P1. The pressure test was performed based on existing 75’ hose. Now I have the numbers of static pressure, nozzle pressure, hose residual pressure and calculated GPM.
What is the best approach to do a calculation to determine if I can replace it by a 100 ft hose?
Thank you.
So
A little more info
Is this to conduct a pump test
Is this an occupant hose station
Is this ????????????
Hi cdafd,
The fire pump was tested. The technician simply attached two different nozzles (1/2”, 3/4”) to existing 75 ft hose during test and had pump pressure, nozzle pressure, hose residual pressure, calculated GPM recorded.
The existing fire hose is standard 1-1/2” hose with 1-1/2” hose nozzle.
It’s an occupant fire hose cabinet.
