LowlySprnkLayoutTech
Does anyone have practical experiance using amp reading to at least reasonable approximate flow from a fire pump? In a situation that metering flow with a pitot is limited for a highrise standpipe acceptance test. I have testing flow meter for top outlet with residual, but measuring flow from other standpipes is an issue. Does reading amps at the controller vs what we had from the pump acceptance test fubar to verify total flow?
