NEC 695.6(G) states "Ground-fault protection of equipment shall not be installed in any fire pump power circuit."
Does this include upstream ground-fault protection all the way to the transformer? This would remove ground-fault protection from all other equipment fed from the substation. Or is it only the circuit the fire pump is on?
