abusementpark
- Dec 23, 2007
- 1,086
I am designing exterior wood walls on a five-story building (over two stories of concrete podium). The studs are fire-rated to meed code. The studs are 2x6 with two layers of 5/8" gypsum on the inside and 1/2" FRT plywood on the outside. I believe the architect only needs a fire rating from the inside (two hours) and that is provided by the two layers of gyp, but the code requires the studs and the exterior sheathing to be FRT.
I am aware of footnote m in Table 721.1.(2) of IBC 2015, which requires major reduction in allowable compressive stress of the studs in various fire-rated walls. It would basically require me to design the 9' long studs for an unbraced length of over 15' only use 78% of the capacity of that. However, the exact assembly I have isn't listed in this table and this footnote is only applied to stud wall assemblies which establish the ratings from both sides of the wall. There are three assemblies listed for exterior walls rated for fire resistance from the inside only, which don't require an allowable stress reduction as indicated by footnote q (this is closer to what I have). However, these three assemblies are only for 1 hour ratings, so they don't exactly match what I have. So, I really don't know if I am supposed to design the studs for this reduction or not. It's odd to me that such a major design factor would be left to some footnote in IBC and not prominently addressed by NDS.
Can anyone provide some guidance?
