Daren Samy
I have seen three times that Plug has been detached from stem of pneumatic control valve. There are three provisions for plug and stem connection.
1. Plug has threaded hold in which thread stem passes through.
2. There is provision of Nut at the end of stem. This but seats on the plug and holds the stem tightly.
3. Diagonal pin that passes press fit through plug and hardly touches stem (may be to avoid rotation of stem)
Why this design of stem is showing failure of plug detachment?
Why not weld the stem and plug to avoid detachment ?
