I have inherited a construction project where the contractor has installed 6inch electrical ducts through the 3’-0”Wide x 2’-0”Deep box drain, thus reducing the drain’s capacity. The pipes cannot be raised as they also cross an adjacent roadway. As a solution, I am considering adding another box drain that attaches to the existing box drain before the pipes, goes around the pipe, then converge downstream, similar to a river bifurcation. The size of the branched drain will be to account for the required overall capacity. Any thoughts?
