Fixed Tube Sheet Heat Exchanger Flexible Shell Elements. Axial load
DK44
IN
1. In the design of Flexible Shell Element (Expansion Bellows) by FEA, for Fixed Tube sheet Heat Exchangers, TEMA RCB-8.5(2) gives following formula for Axial Load calculation:
F axial = (Pi/4)*G^2*100lbf/in^2.
2. In this equation the internal pressure is not figured, instead a term 100 lb/in^2 is used. Calculation without the use of internal pressure does not appear to be in order. Also assuming 100 lb/in^2 generally for all caces does not appear to be appropriate.
3.Can we use Exchanger Shell side Design pressure in place of 100 lb/in^2 in the formula.
Request guidance in the above calculations.
DK44, I think you are going to need to get your guidance from TEMA. This is a highly complex analysis, I suspect the author(s) could best answer your question.
Well, that's just wrong. What the analysis is doing is, is determining the spring rate of a known geometry. A known load is applied and, from the FEA, a displacement is found. The spring rate is then calculated as per 8.5(4) & subsequent.
So, no, the design pressure is not used for this step.
Mike
Actually, I suppose the use of the given pressure is arbitrary, after all, you are applying a load and "measuring" a deflection.
Why the given, 100 lb/in^2, rather than some other value you would have to ask the author(s).
