I have a single page from what appears to be a very old untitled source (book?) that refers to an exhibit (a graph) within the source that can be used to determine the initial selection of an economic hub thickness (g1) of a tapered-hub integral-type flange. Not having the graph, it appears from the instructions that the horizontal axis of the chart is sqrt (B/g0) and the vertical axis is g1/g0. The only example given in the source for its use indicates that when the chart is entered at the bottom at sqrt(B/g0) = 7.75, then the value g1/g0 = 2.35 can be found along the left vertical axis. Of course, knowing this ratio and the value of g0 allows one to calculate g1. I have tried unsuccessfully to find a reference to this specific design parameter. Taylor Forge Modern Flange Design Bulletin 502 simply states: "For starting hub dimensions, g1 ~ 2g0 is suggested". Does anyone know this technical source or the underlying theory or math relationship mentioned?
