Flange Leak Analysis
marchieV
71
Do you usually consider the design temperature in the flange leak analysis using Pressure Equivalent? Or only operating temperature?
Marco
Both design pressure and temperature are normally used, however if other conditions produce more demanding results, you might want to reconsider your design case, or revise your "design" values.
What exactly is "Flange leak analysis"??
Or "pressure equivalent" for that matter.
Ok, that makes sense.
I suspect the syphon post was RF'd as it was clear the OP wasn't an engineer.
