I have to install a new pilot ignition system in an existing flare, but I can't shutdown the flare to perform this job, maybe is there anyway to perform this job, whithout shutting down the flare?
Probably best to contact some flare vendors - this is a fairly risky adventure..... I can't imagine how you would run the unistrut up the stack as a support for the ignition system without potentially endangering workers...
