Flare Tip 1
lganga
109
Friends
We have a Flare Tip that needs be replaced.
The company that fabricated it is not in the business any more.
It Was McGill.
We want to replace it with the same design but smokeless.
Does anybody knows who is following the Designs from MCGILL,we want to contact them.
Any other suggestion to follow will be wellcome
Luis
I'm not sure of your location, but the simplest way is to google 'replacement flare tip McGill' and you'll get several companies specialised in replacement or refurbishment of these flare tips.
Good luck,
gr2vessels
We fabricate flare tips for John Zink, Flaregas and Callidus Tech. from the states but I am certain there are lots of others.
Check out Flaregas Corperation at Flaregas.com, they will be able to help you out with a smokeless flare tip.
warrenw
I am checking it in Internet
