I am designing a small ancillary water system for a brewery and am using a membrane contactor that has sanitary connections on it. The tri clamp connections with the bead groove are straight forward. However, the contactor also has 4 ports meant for gas flow under a vacuum. Those ports look similar to a tri clamp but they have no bead groove and the 3D model appears to show no bevel on the back side. Any help on identifying what kind of connection this is would be most appreciated. I have sent a request to the contactor manufacturer but haven't heard back yet.
