Flat Pattern in same view as model.
jerry1423
3,428
I am on NX1961.
Does anybody have a way to show the flat pattern of a part in the same model view as its formed model ?
I really could use it right now.
Jerry J.
UGV5-NX1961
If you use the "flat solid" feature, it does show ?
( Not the flat pattern feature.)
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.:)
Yes, use the flat solid command. If you already have a flat pattern feature you can make the flat solid external (RMB on flat pattern feature).
Also, depending what you're needing it for, you can create a new window and have the flat pattern open in one window while workoing on the model in the other.
Thank you both very much
Jerry J.
UGV5-NX1961
