ramihabchi
- May 1, 2019
- 98
Is it possible to make a flat slab a half slab precast?(flat slab with perimeter beams of same height of slab and having precast slabs of certain height and covered by cast in place topping)
I found a research on the net where it proposes that adequate transverse connections on joint between precast slabs can make the panels act as two way slab(name of research "experimental study of two way half slab precast using triangular rigid connection")
So I need help on the questions below:
1)the problem with the reasearch is that it states that moment could be transferred transversally with adequate detailing but failure/cracking load in transverse direcrion is 16% less than in the monilithical slab case.so If I want to apply their detailing in the transverse direction I do not know how much load I can let the slab bear to act as two way.any help?
2)the research also shows that not only transverse transfer of moment is possible but also longitudinal transfer. also the cracking happens at 16% lower load than that of monolithical slab.does anyone knows about such detailing?how can I increase reinforcement for slab dimensions other than stated in research(for e.g increase moment by 16%?)
I know that we normaly prevent lapping near mid span but its still possible.thank you
