Hi to all,
I’m have problem with large reinforcement area over columns in flat slab (30cm thick and 8.3m span). I’m in search for some guides how to model column supports to reduce peak hogging moments.
Can you help with ASCE provisions or any other guides, practices in USA.
I’m already found that i can smooth negative moments with modeling column as area support (elastic/rigit), cut momemnts at column edge, reduce peak momonet for degree etc… but I’m curius on which hogging moment you design long spans flat slabs.
Thank you for any comment/suggestion
