Flat Spring Steel Plate
singhjai
3
Hi All,
I am working on designing a flat plate spring with a setup as shown in the attachment. My design intent is to have a indicator in the center which would move to a certain position on the application of 200lb of load. I would be using webbing to pull the spring steel piece on both sides. Is this design even possible? Can this be achieved using a flat spring steel plate?
 https://files.engineering.com/getfile.aspx?folder=4bbe91d1-f885-4d19-9656-e7e97433e300&file=Load_Indicator.docx
