LuisUgarte
Hello everyone,
I've tried to find a good reference to understand, if it is nedeed to consider accidental torsional moment in the seismic design of an industrial building, with flexible diaphragm.
Regardidng industrial buildings we do not consider any rigid diaphragm, instead we use roof elements (tension rods and struts) to provide a good load path for lateral loads. In that case, it is required to consider accidental torsion? If so, how will you distribute that accidental torsional moment between bay frames?
Thank you!
Thank you!
