Soicey75
- Sep 17, 2018
- 7
I am designing a spread sheet for analysis of a solid steel rectangular section that is larger than Lb*d/t^2. I am using AISC 360-16 to attain the flexure capacity of the member but I can't find a condition where my rectangular sections meets in chapter F. I tried using section F.11 for square bars but the yielding state equation can only be applied to members with a Lb*d/t^2 is less than 0.08*E/Fy and my dimensions are larger. Where else in the specs or in other codes can I find functions to work with my beam ?
