duk748
- Jul 18, 2007
- 167
hello - i am designing an acme screw drive in the traditional way - acme nut threaded into a plate that is attached to a carriage mounted on linear bearings for guiding -
acme screw is driven by electric motor w/ coupling & bearing blocks on each end as part of the complete screw assembly (nook standard assembly) - the linear blocks are registered on the carriage & the rail floats - my theory is that if the rail is left loose & you run the carriage back & forth on the rail until the screw is running smoothly then tighten the rail down the screw should not bind - i have heard of a "floating" nut design for screw drives but am not familiar with it - any help or suggestions would be greatly appreciated - thank you
